J
jlh3rd
replied to the thread
an almost stepson needs some advice
ok....thanks for the time frame .....the movement is at the top only, it's minor but not right. bearings, seals, washers seem a...
Sep 22, 2026
redneck joe
iboats Football Pick 'em is back!
want to take the browns over panthers, i'm going to stew on that one colts upset over houston titans - see above bucs over vikes never...
Sep 22, 2026
M
muc
377 mag mpi dts Hard start after the first time
Yes, this engine uses and needs the cam sensor to run. Yes, you can swap them. No, I don't know if it's easy. This engine has 8 injector...
Sep 22, 2026
Lou C
Ok a question about points systems….
Thanks for this! It makes sense with what Scott said the part I didn’t quite understand is the actual amp draw in the coil primary...
Sep 22, 2026
redneck joe
Help Identifying Boat
Sep 22, 2026
redneck joe
oh and welcome to the forum The HIN was required after 1972, the MIC after '84
Sep 22, 2026
Tim Frank
8 hp E'rude 1990 ... bonehead move
Thanks for the comments. 1. Compression is just over 100-PSI on both cylinders. 2. Idles well, but coughs and smokes a bit as it is...
Sep 22, 2026
Fun Times
Alright, I broke a rule but this should be fun… I asked AI on a points ignition system, does the coil voltage rise and drop depending...
Sep 22, 2026
Lou C
Spark knocking diagnosis
I’d be looking at fuel mix and also what’s the max RPM you get? If it’s over propped (prop pitch too high, max rpm too low) you will...
Sep 22, 2026
Lou C
Makes sense though I am surprised that the difference was that much…,
Sep 22, 2026
Reach out to your local Michigan registration office. you will need either the title of the boat or the prior owners signed...
Sep 22, 2026
Horigan
reacted to
Donald0039's post
in the thread
Engine does not seem to be pulling in water from muffs
with
Like
From my reading the vanes will flip if installed with the vanes curling in the wrong direction. And the hoses on my raw water pump are...
Sep 22, 2026
Horigan
2008 338 Four Winns
Ask for a pressure test and vacuum test of the drives. One of the seals may be close to failing.
Sep 22, 2026
aspeck
IF you find the parts and IF everything goes well, you are looking at 2-2.5 hours labor. Add more time for corroded/seized bolts, nuts...
Sep 22, 2026
aspeck
reacted to
Captain Caveman's post
in the thread
Help - Boat Accident and Insurance
with
Like
Thanks JustJason. That was the kind of great information that I was hoping to learn. It is a big insurance company - one of the good...
Sep 22, 2026
