redneck joe
replied to the thread
2008 338 Four Winns
could water be condensation from just sitting around if it was a dock queen or on the hard for extended time?
Sep 23, 2026
dingbat
deck waterproofing
Where did you read that? Greying is typically a UV issue
Sep 23, 2026
redneck joe
posted the thread
way to ruin the 20 year anniversary boat day
in
Boat Topics and Questions (not engine topics)
Had not splashed yet this year aka life happens. But 18/20 anniversary so thought i must take the time and make the effort life can wait...
Sep 23, 2026
M
Mc Tool
reacted to
Chris1956's post
in the thread
Stuck Steering
with
Like
Usually if you can rock the shift rod front to back with a pipe or monkey wrench, with penetrating oil and some rags for cleaning the...
Sep 23, 2026
M
Mc Tool
reacted to
tphoyt's post
in the thread
Light corrosion in cylinder BF130
with
Like
A clean piston like that is usually caused by water intrusion. Look at the head gasket and see if you can tell if it was leaking. And...
Sep 23, 2026
redneck joe
deck waterproofing
i don't mind grey as long as water beads
Sep 23, 2026
M
Mc Tool
Ignition Troubleshooting - 1978 700
Mmmm bugger ! Looks like there are 3 either bulges or discolorations down the left side adjacent to the three nuts on the right side...
Sep 23, 2026
M
Mc Tool
Wood stove install
I have a 5kg cylinder of Co2 with a bit of hose on it , never used it on a fire but it doubles as a spare welding cyl and we used it...
Sep 23, 2026
C
deck waterproofing
According to the internet, that stuff is water based. Says it penetrates but allows the wood to weather to a grey color. That seems to...
Sep 23, 2026
redneck joe
deck waterproofing
so here is what i went with, looks good - the second coat gives a bit of coated look. First coats soaks in good, roll on more when...
Sep 23, 2026
redneck joe
Wood stove install
what about a chimney flare - any thoughts on those?
Sep 23, 2026
redneck joe
reacted to
Jeff J's post
in the thread
Wood stove install
with
Like
A piece of light log chain will fall through a 45. Rattle it around a bit and most of the chucks will fall out. I have responded to...
Sep 23, 2026
B
Buster53
1991 sea ray 310 electrical problems
Yes, as mentioned, the picture shows just the 120 volt side of your boat’s electrical system. Take a picture of your dash or wherever...
Sep 23, 2026
Lou C
Milky oil
You certainly can do that, but keep in mind that you'll probably see mostly Vortec heads that won't work with the pre-Vortec intake...
Sep 23, 2026
redneck joe
reacted to
Bwillson18's post
in the thread
OMC Cobra Help (cable adjustments)
with
Like
I saw some videos of people using this, Ill grab one for next time. Like i said though I spent a good couple hours finding dead center...
Sep 23, 2026
