S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
Compare the casting #s of the heads, you want a pre-Vortec head to match the other side, assuming it is OK. Now if it's a pre-Vortec...
Sep 24, 2026
A
airshot
reacted to
redneck joe's post
in the thread
Random
with
Like
Sep 24, 2026
K
ktholiday
replied to the thread
1966(?) Starcraft Holiday – Former U.S. Army Corps of Engineers Boat Restoration
I think it's a 66 holiday 18
Sep 24, 2026
Lou C
OMC 250 hp rough idle, back fires through carb on load
I wound up measuring mine, it was .010, which isn't bad, as long as I don't have a hunting idle I'll leave it be. BTW, I have found...
Sep 24, 2026
P
peters715
Entire electrical system dies when under way
Also I replaced the switch. All new gear from battery to starter.
Sep 24, 2026
Lou C
Milky oil
More on Chevy 4.3 casting #s, I think the ones here are just the last 3 digits of the longer casting #, pulled this off of an ad selling...
Sep 24, 2026
aspeck
reacted to
redneck joe's post
in the thread
Boats from work.
with
Like
best sales people in my experience who worked for me over the years are people that do the work, know the work, believe in the work...
Sep 24, 2026
JimS123
Firestone Serial Number
I answered my own question. It was embossed on the side of the power head. It was so greasy and corroded that it didn't show up until...
Sep 24, 2026
Lou C
Milky oil
look here you can find your engine casting # and match the OE cylinder head you are keeping to the casting # in that list to figure out...
Sep 24, 2026
Lou C
Milky oil
Sep 24, 2026
T
tphoyt
Random
Well it’s good your stain was dry.
Sep 24, 2026
R
Rochester_Rob
Thank you. I will try that. I have hooked up a vacuum gauge and the vacuum is kind of erratic with the bad idle. When it occasionally...
Sep 24, 2026
P
peters715
Thank you all! The battery to switch cable had a lot of corrosion at the switch. The switch connection was melting too. So I replaced...
Sep 24, 2026
S
SeaRayboater95
Milky oil
Found a head but I have to remove it from the boat myself. Do I need to use the push rods and rockers from that head, or can I use the...
Sep 24, 2026
9
99yam40
Fuel pressure too high, how to fix? Small block GM V8
I would think if there are no fuel pressure regulators then the pump itself would have something to control the pressure. that is why I...
Sep 24, 2026
