Lou C
replied to the thread
OMC 250 hp rough idle, back fires through carb on load
If a valve spring was weak, it makes sense that the intake valve might not close fully and then the ignited fuel/air mixture could...
Sep 25, 2026
Captain Caveman
Cancer. My turn in the barrel.
Fight to win brother
Sep 25, 2026
C
Snapped a rod
Gee, I just buy Ugly Stiks. I haven't broken one of those yet.
Sep 25, 2026
FLATHEAD
Snapped a rod
Go for it. I like doing split grips because you can hide the ends of thread wraps under the cork. I cut, glue up, and turn my own cork...
Sep 25, 2026
Scott06
Milky oil
would think as long as the chamber size is the same should work. Did the other head check out ok? would assume this is from an over heat...
Sep 25, 2026
D
DeepCMark58A
I hope you have support thru your journey.
Sep 25, 2026
FLATHEAD
reacted to
Scott Danforth's post
in the thread
Snapped a rod
with
Like
not bad..... is that all thread work, or is that also pinstriping? I have two busted carbon fiber rods I keep saying I want to rebuild.
Sep 25, 2026
FLATHEAD
reacted to
flashback's post
in the thread
Snapped a rod
with
Like
That's very cool, I didn't know folks did stuff like that. been under a rock too long.
Sep 25, 2026
FLATHEAD
reacted to
aspeck's post
in the thread
Snapped a rod
with
Like
Nice work!
Sep 25, 2026
FLATHEAD
reacted to
dingbat's post
in the thread
Snapped a rod
with
Like
Looks good…. I have a couple of blanks in the shop I glued up (split grip handles) and sat aside 2 years ago. Maybe this will give me a...
Sep 25, 2026
G
GoDawgs999
Having Problems with 1997 Mercury 150HP EFI V6
But if i do take the control moudule off, wouldn't it take the temperature or rotation sensor off sum like that too? also to be sure its...
Sep 25, 2026
redneck joe
1997 Mirrocraft 18' aluminum fish n ski
remind me, why are you draining tak and carbs? Seems you had it on the lake already?
Sep 25, 2026
redneck joe
reacted to
BWR1953's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
I had a pair of '82/82 Merc 70hp engines, one had been running when I got it years ago, the other wasn't. I did the carb rebuild on the...
Sep 25, 2026
K
kenny nunez
There is a tool to test the springs on the heads without removing them. There may be one that can be rented from one of the big box auto...
Sep 25, 2026
Lou C
reacted to
SeaRayboater95's post
in the thread
Milky oil
with
Like
Shop tested and said it was good.
Sep 25, 2026
