Berdink
reacted to
Scott Danforth's post
in the thread
Tips for Removing Fuel Pump.
with
Like
Block of wood up against the edge. ..smack with a hammer
Sep 26, 2026
replied to the thread
Cancer. My turn in the barrel.
Best of luck
Sep 26, 2026
Sep 26, 2026
new vinyl and possible layout change
I would replace the wood with PVC foam board on that bolster
Sep 26, 2026
redneck joe
reacted to
BWR1953's post
in the thread
1997 Mirrocraft 18' aluminum fish n ski
with
Like
Only if it's hooked up to a fuel source, which it isn't right now. That would be a good way to test. I could hook up a fuel tank, pump...
Sep 26, 2026
tpenfield
reacted to
alldodge's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Like
Here is the one for Verado's The first thing I usually do after getting new car/truck/motor I go a buy spares. I need to start doing...
Sep 26, 2026
redneck joe
i think im going to so some sort of spacer on that one.
Sep 26, 2026
redneck joe
Sep 26, 2026
redneck joe
only bad piece on the boat
Sep 26, 2026
Dukedog
water tube seal
tha "seal" in question is tha one that presses into tha end of tha crank.. it keeps water out of tha bottom of tha motor.... part...
Sep 26, 2026
Berdink
posted the thread
in
Mercury & Mariner Outboards
1978 Mercury 70hp I've been pulling on it, hitting it with a rubber mallet, and it's stuck good. I sprayed some PB Blaster around the...
Sep 26, 2026
Berdink
Ignition Troubleshooting - 1978 700
My shopping for a new one I'm noticing they all have BLK/YEL where mine has ORN for Orange. . Mine might likely be a pretty old one. ...
Sep 26, 2026
P
Pmt133
I have a bout a dozen oil filters for my daily. About 3 years worth of service.
Sep 26, 2026
C
Crosbyman
1975 Johnson 6hp (6RL75R) — idle timing off due to play in throttle shaft, need diagram of shaft/socket coupling
Sep 26, 2026
Berdink
reacted to
Chris1956's post
in the thread
Stuck Steering
with
Like
That steering cable may be beyond saving. I presume it is a rotary system with the cable pulled out of the helm?
Sep 26, 2026
