nola mike
replied to the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Aren't you on Nantucket or the vineyard?
Sep 27, 2026
D
Drivewayboater2
reacted to
eggs712's post
in the thread
1985 Bayliner 2750 Ciera Sunbridge Resto
with
Like
Boat ran well... mostly. 20 hours on her now, going to do the second oil change when the rubber oil pan hose arrives (hopefully easier...
Sep 27, 2026
Keith7481
O2 sensor replacement
Closed cooling,,, idled for 5 minutes, I could touch it, but much hotter than starboard
Sep 27, 2026
Keith7481
Thanks, I was think about plug replacement, but that requires a visit to the shop. I thought since I can do the sensor first myself...
Sep 27, 2026
I'm assuming open cooling A motor at idle in most cases does move enough water to fill everything the same as higher RPMs, if it's on a...
Sep 27, 2026
Texasmark
Tips for Removing Fuel Pump.
Agree....like water pump impellers....since you went to the trouble to inspect it, why shouldn't you replace it?
Sep 27, 2026
Texasmark
reacted to
Scott Danforth's post
in the thread
with
Like
Block of wood up against the edge. ..smack with a hammer
Sep 27, 2026
P
Pmt133
I tell people they're stupid for living on a barrier island that floods at normal high tide. These are the find out calls.
Sep 27, 2026
Lou C
You want to find out why that side of the exhaust is so hot, it could be a lean condition but without a scanner that reads live data...
Sep 27, 2026
T
tphoyt
Fuel leakage problem.
OEM carb kit? Fuel spilling out is usually a stuck float. Cheap kits are not always good and have mismatched parts. Float level set...
Sep 27, 2026
Lou C
Lucky for us we live on top of a hill so we’re about 90’ above sea level. The part of our neighborhood by the boat yard I’m sure had...
Sep 27, 2026
Keith7481
posted the thread
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
Earlier this summer my 2016 VP 350 with closed cooling was throwing a code for the port bank running lean. I had the code cleared and...
Sep 27, 2026
Grub54891
portable fuel tank quick disconnect
Switched a couple of mine to these Myself. No leaks and I think they are easy to hook/unhook.
Sep 27, 2026
aspeck
reacted to
BWR1953's post
in the thread
Cancer. My turn in the barrel.
with
Like
The docs tell me that my cancer is very survivable. :) Survival rates are 85-90% after 8 years, so that's good. The radiation...
Sep 27, 2026
P
Pmt133
We had 3 calls to flood zones so far.
Sep 27, 2026
