redneck joe
replied to the thread
Removing the side panels of angler 220 wa
yeah, and sealant. does the lip move at all when screws are out?
Sep 27, 2026
K
k_petro
Yes I did all screws are out
Sep 27, 2026
flashback
Someone else's outboard conversion fail
I'm surprised the skeg is still there..
Sep 27, 2026
flashback
reacted to
Chris1956's post
in the thread
with
Like
To be fair, the motor is just a bit low. If it was up a few inches, and you never plan to tilt it up, run it!
Sep 27, 2026
O
OldGuy77
posted the thread
1990 Mercury 2.4 V6 175 - Water leaking from power head, exhaust adapter plate connection and rattle - when engine cranked dry - runs good no rattle.
in
Mercury & Mariner Outboards
This started 2 years ago - since that time I have rebuilt the power head because the rattle was thought to be a rod bearing due to...
Sep 27, 2026
N
needin some help
Fuel leakage problem.
I checked float level per this site, I, unwillingly, am going to pull the carb again and check things out, I did use the original float...
Sep 27, 2026
flashback
reacted to
redneck joe's post
in the thread
with
Like
so that panel, after you remove the screws is not coming out? If so my complete guess is it is spray foamed in place and acting like a glue
Sep 27, 2026
C
Sep 27, 2026
flashback
did ya take the screws out? looks like they're still in. and yes, it was most likely installed with a sealant.
Sep 27, 2026
N
needin some help
Kit was Sierra
Sep 27, 2026
K
k_petro
I understand the same because it does not move. I tried also to move it at the fire after direction also up and down in case there was...
Sep 27, 2026
flashback
reacted to
Scott Danforth's post
in the thread
Random
with
Like
Squirrel......AKA tree rat
Sep 27, 2026
redneck joe
reacted to
bakerjw's post
in the thread
with
Like
I need this... That said, an Armstrong bracket would be the answer.
Sep 27, 2026
Berdink
reacted to
Texasmark's post
in the thread
Tips for Removing Fuel Pump.
with
Like
Agree....like water pump impellers....since you went to the trouble to inspect it, why shouldn't you replace it?
Sep 27, 2026
Berdink
reacted to
in the thread
with
Like
Since you pulled it apart, put a kit in it
Sep 27, 2026
