redneck joe
reacted to
Harkonnen's post
in the thread
R/V Port Yankee construction
with
Like
Bulkheads and stringers added, hull crated up and flipped. Mower in the back serves as a brake to keep the hull going over too fast and...
Sep 27, 2026
redneck joe
replied to the thread
iboats Football Pick 'em is back!
actually wasnt that bad of a hit
Sep 27, 2026
C
1990 Mercury 2.4 V6 175 - Water leaking from power head, exhaust adapter plate connection and rattle - when engine cranked dry - runs good no rattle.
You might check the powerhead for water leaks into the cylinders. Maybe an endoscope in the cylinders? Water leaks into the cylinders...
Sep 27, 2026
66Holiday924
reacted to
IslandExplorer's post
in the thread
1974 Chieftain 25 "Adventurer" Restoration
with
Like
Still needs a couple last screws put in and for the divider and door cathches to be installed- but the admiral's 1953 naval crate galley...
Sep 27, 2026
66Holiday924
reacted to
in the thread
with
Like
Sep 27, 2026
Fun Times
Looking for 243 Cockpit table
Sounds like you'd want the tabletop to double as a bed filler as one thought to share would be would any other tabletop work out should...
Sep 27, 2026
66Holiday924
1978 Islander 22 I/O
Check out what I found for $80 and some driving. It needs new fittings and I'm going to look into having the railing anodized.
Sep 27, 2026
66Holiday924
More floatation foam work, I formed my rubber storage pails in the foam like I did my port-a-potty. The expanding floatation foam is...
Sep 27, 2026
T
tphoyt
reacted to
metalchewy's post
in the thread
Nobody fishing?
with
Like
Was out on Lake Mead yesterday, launched from Calville Bay. Pulled up to a point in a cove we like to fish, and just drifted with the...
Sep 27, 2026
metalchewy
Nobody fishing?
Sep 27, 2026
M
muc
O2 sensor replacement
Yes, aluminum doesn’t rust, it corrodes. The anodes are there to sacrifice themselves to protect the aluminum.
Sep 27, 2026
reginaldo
best way to rejuvinate your cars headlight lenses ?
Have had decent luck buffing with a foam drill attachment and the spray, think it's usually a 2-part but been a few years. The 2k...
Sep 27, 2026
M
muc
Alignment Tool for Aplha One Gen 2
If you have good alignment and those rear mounts don’t move more than 2-3 mm when you first go from idle to WOT in the water —- rear...
Sep 27, 2026
dwouscg
posted the thread
in
Chaparral Boats
I have a new to me 2004 Chaparral Sunesta 254. It is missing the cockpit table(item# 4-1061). I do have both post lengths and the...
Sep 27, 2026
Berdink
reacted to
Mc Tool's post
in the thread
What is This? It has Mercury on it.
with
Like
Well I always use gps sog in my boat because Im always travelling between two points of land a certain distance apart and thusly my...
Sep 27, 2026
