Scott06
reacted to
alldodge's post
in the thread
2001 Mercruiser 5.7 EFI/TBI Scan Tool
with
Like
That is a MEFI (1 to 4) connector and while there are not many codes can be read, if there is one it can be done as your pic shows. Use...
Sep 28, 2026
redneck joe
replied to the thread
How do i get this out?
^^what he said^^
Sep 28, 2026
Fun Times
Like mentioned above, if you're just wanting to read trouble fault codes on the MEFI ECM's only type then the following way using a...
Sep 28, 2026
9
99yam40
Entire electrical system dies when under way
does this happen every time you hit the T&T? Or only while underway? I would be checking to see how much current the T&T pulls and what...
Sep 28, 2026
toilet bowl cleaner contains oxalic acid
Sep 28, 2026
garbageguy
reacted to
redneck joe's post
in the thread
Random
with
Like
a cool nerd however... for those that are not as cool as me the song here is the song in the opening in the first movie with Chris...
Sep 28, 2026
Engine Dies. Sputters
Don't know what to think without testing, but IAC would not be first thought because it will start without giving more throttle. Looks...
Sep 28, 2026
garbageguy
reacted to
Scott Danforth's post
in the thread
best way to rejuvinate your cars headlight lenses ?
with
Like
you can go thru the effort of sanding with 600 grit, then 800, then 1000, then 1200, then 1500, then 2000, and polish them about 2-3...
Sep 28, 2026
Lou C
RV build quality - Rant
Nice work there!
Sep 28, 2026
E
ejput
That helps a lot!! Thanks
Sep 28, 2026
S
Snowjnnp
reacted to
puddle jumper's post
in the thread
89 Bluefin Spectrum 1703
with
Like
Re: 89 Bluefin Spectrum 1703 mine is a 20 gallon pj
Sep 28, 2026
muskyfins
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
2011 Formula 290 SS 350 Mag MPI SN 1A619395 654 hours Lakes were no wake due to high water. Idled out to our spot (6 miles) no issues...
Sep 28, 2026
G
gman546
UPDATE: Got the boat out, powerwashed 3 coats of spray nine bottom cleaner and this is whats left. I've got the Oxilic acid as...
Sep 28, 2026
Lou C
Agreed polish lasts for a while but unless you coat them with the urethane clear it doesn't last more than a year. I just replace them...
Sep 28, 2026
Sep 28, 2026
