T
taka
replied to the thread
Yamaha F250A 6P2 – Code 72 Above 4000 RPM After Warm-Up
Yes. According to the Yamaha service manual, code 72 is related to the PORT intake cam position sensor / signal. That is why I swapped...
Sep 28, 2026
ezbtr
reacted to
redneck joe's post
in the thread
cooking
with
Like
new town has a grocery outlet that has chops with actual fat in and on. Had some good ones off the grill last few months. Cheap to...
Sep 28, 2026
ezbtr
reacted to
metalchewy's post
in the thread
Nobody fishing?
with
Like
Was out on Lake Mead yesterday, launched from Calville Bay. Pulled up to a point in a cove we like to fish, and just drifted with the...
Sep 28, 2026
Berdink
1978 Mercury 70hp Adding Power Tilt Trim
Okay, so Ai is an idiot! Are there later models that I can harvest power trim tilt?
Sep 28, 2026
T
tphoyt
reacted to
redneck joe's post
in the thread
cooking
with
Like
Sep 28, 2026
9
99yam40
do you know what code 72 means? i would be looking that up if I thought my motor was sending that code.
Sep 28, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
One thing you could do: look up those parts in a mercruiser parts manual online. See if the part numbers are the same for the years...
Sep 28, 2026
T
taka
Yes. It is the engine warning icon in the upper right of the tachometer shown in the photo. It flashes 7 times, pauses, then flashes 2...
Sep 28, 2026
Berdink
Ha! "Artificially" Intelligent.
Sep 28, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
Once again AI may be wrong.----Pretty sure power trim was an option in 78
Sep 28, 2026
R
Sep 28, 2026
R
1968 Sportwin water trickle top of power head
Top retainer plate on the starter?.----Replace gasket under it.----Simple I think.
Sep 28, 2026
P
peters715
reacted to
99yam40's post
in the thread
Entire electrical system dies when under way
with
Like
You need to monitor the battery voltage and the voltage at different places before starting and after. with motor running you should be...
Sep 28, 2026
P
Pmt133
cooking
That's a proper chop.
Sep 28, 2026
B
boscoe99
Are you talking about the warning coming from the tachometer? Where on the tachometer are you seeing this?
Sep 28, 2026
