Scott06
reacted to
Fun Times's post
in the thread
Ok a question about points systems….
with
Like
Alright, I broke a rule but this should be fun… I asked AI on a points ignition system, does the coil voltage rise and drop depending...
Sep 29, 2026
replied to the thread
Stratos trailer
call EZ loader since its an EZ loader trailer
Sep 29, 2026
How do i get this out?
contains oxalic acid
Sep 29, 2026
Texasmark
reacted to
Mc Tool's post
in the thread
What is This? It has Mercury on it.
with
Like
Its a speedo pick up ....water is forced up that tube and goes to a pressure gauge on the dash that has mph on the dial .....pretty...
Sep 29, 2026
Texasmark
reacted to
Mc Tool's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
Yeah , its not like they stretch a 50hp up to 70hp , they build a 70 hp and then detune it down to 50hp . Some things are hard to change...
Sep 29, 2026
Texasmark
One of my granddads had a small farm and liked for me to help him plant when that time would come. On one occasion we were heading back...
Sep 29, 2026
S
SeaRayboater95
reacted to
Lou C's post
in the thread
Milky oil
with
Like
I’m wondering why there’s like .010” difference in length? GM did so many odd things like mixing SAE & metric fittings it’s not...
Sep 29, 2026
JonBoat55
StarBright hull cleaner
Sep 29, 2026
P
pspagna
posted the thread
97 Johnson 130 Tilt banging when going up and down
in
Johnson & Evinrude Outboards
Hello, Has anyone ever had the issue of the tilt banging at certain intervals going up and down. Seems to tilt ok, can go all the way...
Sep 29, 2026
Lou C
Stratos trailer
No numbers but you can figure out the capacity by inspecting the trailer bearings (#s) and tires. Then weigh the trailer and subtract...
Sep 29, 2026
E
Ericavictoria
posted the thread
Idles 1000rpm in neutral and runs a litte rough
in
Hi, my Johnson 70hp 2000 idles high on neutral if its going to idle att 700 in gear. It also runs a little rough on idle. I’ve had many...
Sep 29, 2026
Lou C
Milky oil
Sep 29, 2026
Lou C
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
Close, Centerport which is right between Huntington & Northport At the docks in Northport we see boats from Ct all the time. It’s only...
Sep 29, 2026
R
reacted to
Chris1956's post
in the thread
1978 Mercury 70hp Adding Power Tilt Trim
with
Like
I think you need a PTT unit from the 3 cylinder Mercs starting in the early 70s. I think you can also use one from the 4 cylinder 50HP...
Sep 29, 2026
tpenfield
@Lou C . . . Northport? :unsure: I got my boat in Port Washington / Manor Haven
Sep 29, 2026
