JimDirt
reacted to
redneck joe's post
in the thread
old pictures
with
Like
here ya go
Sep 29, 2026
P
peters715
replied to the thread
Entire electrical system dies when under way
Well, I went through every connection in the engine compartment. Polished every single point of contact and measured voltages before...
Sep 29, 2026
redneck joe
Wood stove install
In the cieling are storage bins hanging in the rafters. Windows are off, the whole thing is whack. Verticals are pretty good need to...
Sep 29, 2026
N
needin some help
Fuel leakage problem.
I saw these the other day, put it in my cart. Am waiting to see what happens with my old one, and no particles are coming off the...
Sep 29, 2026
T
taka
Yamaha F250A 6P2 – Code 72 Above 4000 RPM After Warm-Up
I have also attached a video showing the warning. The engine warning icon flashes in a very consistent pattern: 7 flashes, a pause...
Sep 29, 2026
C
Crosbyman
Need help w my 2001 johnson ocean pro 115hp
fwiw here is one answer from an intelligent source... Q: what would cause the bendix gear on a 2001 johnson ocean pro 115hp outboard...
Sep 29, 2026
C
Crosbyman
1968 Sportwin water trickle top of power head
possibly... with age everything shrinks...
Sep 29, 2026
L
Lamont407
posted the thread
in
Johnson & Evinrude Outboards
I have a 2001 johnson ocean pro 115hp outboard motor. When I initially turn the key the bendix goes up an engages with the flywheel as...
Sep 29, 2026
Lou C
Milky oil
https://michiganmotorz.com/4-3l-marine-engine-1993-95/ this is what you have, the adjustable valve train used on millions of Chevrolets...
Sep 29, 2026
T
The Worminator
Do those skirts shrink over time? I can see light passing right through on both sides on both motors!
Sep 29, 2026
reacted to
flashback's post
in the thread
[SPLASHED] I/O (Sterndrive) Conversion to Outboards
with
Haha
Might need to disconnect them until the engines catch up.
Sep 29, 2026
Lou C
Milky oil
If you can't find a good resource, I can find the pages in my OMC shop manual that explains how to do it and post up a pic. Suggestion...
Sep 29, 2026
Lou C
Milky oil
Nope that spec is the newer net lash (non adjustable) style. You have the older classic adjustable style. There's a whole procedure that...
Sep 29, 2026
flashback
Sep 29, 2026
T
tphoyt
Wood stove install
Figured as much but you will likely need to be out another 18 to 24 inches when all said and done so you will have more room up top on...
Sep 29, 2026
