redneck joe
replied to the thread
Signature 240 Helm seat failure
get what in there?
Oct 1, 2026
R
Fuel leakage problem.
I suggest you inspect it.----Then replace the impeller!
Oct 1, 2026
M
Mc Tool
reacted to
Chris1956's post
in the thread
Need help w my 2001 johnson ocean pro 115hp
with
Like
The Bendix will kick out and not re-engage, when the motor fires. It is a common problem on all engines and can be solved by tune up or...
Oct 1, 2026
M
Mc Tool
reacted to
Chris1956's post
in the thread
with
Like
That is not usually a starter issue. The bendix is designed to kick out when the engine fires. The engine is not supposed to fire only...
Oct 1, 2026
C
Propeller advice
Buying the wrong pitch or style of stainless prop is an expensive mistake. I would dial in the pitch and style of the prop with an...
Oct 1, 2026
C
Oct 1, 2026
N
needin some help
Didn't run it long enough for damage to occur, after putting on water hose pump worked just fine , good water flow from exhaust but will...
Sep 30, 2026
ezbtr
best way to rejuvinate your cars headlight lenses ?
what do you use?
Sep 30, 2026
ezbtr
reacted to
Sprig's post
in the thread
with
Like
I want to elaborate a little on this subject. I researched it thoroughly a few years ago , even spoke to an engineer friend. Most modern...
Sep 30, 2026
R
likely needs a new impeller now.
Sep 30, 2026
N
needin some help
Yes, I ran it about 15 or 20 seconds shut it off then pulled it over to the water and hooked it up to the water and ran it for about 3...
Sep 30, 2026
F
FtWorthHorn
reacted to
TRH299's post
in the thread
1986 Ski Nautique 2001 resto project
with
Like
I see why upholstery shops charge so much.... Takes a ton of time to do this work. I am getting a little quicker as I am wasting less...
Sep 30, 2026
L
Luray Lou
I can’t get in there, which is why I was asking. I will see if I can get it apart.
Sep 30, 2026
flashback
Porter Cable BN200
I had a pc finish nailer and all the rubber in it crumbled, I got a harbor freight gun that could use the same nails as I have a bunch...
Sep 30, 2026
ezbtr
rant
I gotta get mine looked at AGAIN, prob pt again, xrays show the lovely abuse, I work out almost every day, some days light always hang...
Sep 30, 2026
