WIMUSKY
reacted to
redneck joe's post
in the thread
Just thought I'd share a nice photo.
with
Like
a few years back, my assistant Fred trying to help with the house re-plumb. his first experience with pex so i cut him some slack...
Oct 1, 2026
redneck joe
reacted to
Scott Danforth's post
in the thread
Random
with
Like
Oct 1, 2026
redneck joe
replied to the thread
Oct 1, 2026
C
Propeller advice
The OP stated that he can get 4800 with a 19P prop, and above that RPM he ventilates. Redline is 4600, right? I think he should try a...
Oct 1, 2026
C
Mercury 500 50 hp reed stop question
OEM Reed valves do not usually go bad. They may be slightly open at rest, but close well enough to seal. If the motor doesn't idle...
Oct 1, 2026
C
Need help w my 2001 johnson ocean pro 115hp
The bendix engages the ring gear when the starter starts to spin. Once the bendix gear is kicked out, the starter and gear must come...
Oct 1, 2026
Porter Cable BN200
https://www.mcmaster.com/products/backup-rings/ https://herculesus.com/
Oct 1, 2026
Porter Cable BN200
If you have a diameter of the piston, groove and groove thickness, should be easy to find from either McMaster Carr or the Hurcules seal...
Oct 1, 2026
aspeck
2026 NFL/CFB News and Nonsense
Joey Porter, Jr is now a Cowboy.
Oct 1, 2026
9
995jim
posted the thread
bravo 1 u joint
in
Mercury MerCruiser Sterndrives & Engines
Hello, my bravo1 has developed a new noise. I just had my transom and stringers at engine restructured. After a few trips out on the...
Oct 1, 2026
flyingscott
reacted to
Mc Tool's post
in the thread
What is This? It has Mercury on it.
with
Like
Its a speedo pick up ....water is forced up that tube and goes to a pressure gauge on the dash that has mph on the dial .....pretty...
Oct 1, 2026
flyingscott
reacted to
jimmbo's post
in the thread
1978 Mercury 70hp Worth Messing With?
with
Like
Just because the Displacement is the same, doesn't mean a change in Jets or Timing will turn a 50hp into a 70hp. Porting, Pistons...
Oct 1, 2026
flyingscott
Check your bushings that the upper bendix rides in.
Oct 1, 2026
flyingscott
reacted to
saltchuckmatt's post
in the thread
Fuel leakage problem.
with
Like
Old cork floats for me have not been nice ...mis-behaving mostly. Particles float off and plug the carb. Do they not make an upgrade...
Oct 1, 2026
T
tphoyt
reacted to
in the thread
Random
with
Like
Oct 1, 2026
