M
MikeSchinlaub
replied to the thread
Boats from work.
Oct 1, 2026
T
tou lor
2001 Mercury 115HP EFI 4 stroke tachometer not working
Wow , this is technical. nice job men>.i have the same issue with the green wire from the ECM plug at .22v only..base on your last pic...
Oct 1, 2026
Berdink
reacted to
Nordin's post
in the thread
1978 Mercury 70hp Adding Power Tilt Trim
with
Like
Check out the 3-cylinder 50 and 60Hp from mid 80.es. I think from 1985 (red-black-brown decals on the hood) and up, PTT from those might...
Oct 1, 2026
Berdink
reacted to
redneck joe's post
in the thread
with
Like
i have an 82 50hp and the two rams are on the sides so i would think it would fit but not sure. I am sure that the cost of finding an...
Oct 1, 2026
Berdink
reacted to
racerone's post
in the thread
with
Like
The 3 cylinder 65 HP beginning in 1972 had the trim / tilt unit that will fit the 70 HP models.
Oct 1, 2026
reacted to
flashback's post
in the thread
bravo 1 u joint
with
Like
Sometimes a slight trim adjustment will make a difference.
Oct 1, 2026
reacted to
Scott06's post
in the thread
bravo 1 u joint
with
Like
I would recheck the alignment several times and rotate the coupler 90 deg 4 times to check alignment through the arc of coupler...
Oct 1, 2026
frustratedboater
posted the thread
07 df250 Valve Shim Question
in
Yamaha & Suzuki Outboards
Good afternoon, I am looking to check/adjust my valve clearances on my 2007 Suzuki df250z and looking for conformation on what type of...
Oct 1, 2026
M
Mc Tool
Mercury 500 50 hp reed stop question
The reed stoppers are there to limit how far the reeds can open , you may gain a little power by bending them open a bit more but you...
Oct 1, 2026
Lou C
old pictures
Post # 79, definitely a Pontiac
Oct 1, 2026
reacted to
SeaRayboater95's post
in the thread
Milky oil
with
Like
Figured out hoe to get pics from manual #18.my serial # is F769949
Oct 1, 2026
vuk_klek
thanks for the answers, I chose the reed valves to lie completely or with a very small gap of only 0.05mm. I saw somewhere on youtube...
Oct 1, 2026
B
bakerjw
reacted to
Stinnett21's post
in the thread
Help Identifying Boat
with
Like
Post on TinBoats.net. I bet someone over there would know immediately.
Oct 1, 2026
B
bakerjw
reacted to
redneck joe's post
in the thread
with
Like
cool. Start a rehab/rebuild/get it working thread we love to spend your money. Start it at the below and if you discover the make a...
Oct 1, 2026
M
Mc Tool
Yeah , as long as they are not damaged a reed hanging open ....even up to a mm is ok , they slam shut pretty quick when the air starts...
Oct 1, 2026
