P
Pmt133
replied to the thread
Ever have a car oil clean for long time?
Not that it's really a function or indication of how well used the oil is or anything (color). But my 19 running 6.5-7.5k oil change...
Oct 4, 2026
flashback
reacted to
alldodge's post
in the thread
Porter Cable BN200
with
Like
I ordered the part yesterday and it's black. The one that was in the tool was like the one on ebay and was crumbling. Figured I'd try...
Oct 4, 2026
dingbat
safety chain question
The hooks are the weakest link. The “S” type hooks are the worst of the worst. The class 4 hitch on the F150 has poor/inconvenient...
Oct 4, 2026
Porter Cable BN200
Oct 4, 2026
L
Lpgc
1978 Mercury 70hp Worth Messing With?
I had an '81 Mercury 3 cylinder 70hp engibe on a 14ft boat around 15 years ago. It was running rough when I bought it and I found...
Oct 4, 2026
Porter Cable BN200
https://www.ebay.com/itm/127609150791
Oct 4, 2026
E
ejnichol
Porter Cable BN200
Part # 15 is prone to failing and is even harder to find.
Oct 4, 2026
E
ejnichol
reacted to
flashback's post
in the thread
Porter Cable BN200
with
Like
If you use them every day they last longer. Sitting on the shelf in a shed they dry out.
Oct 4, 2026
L
Lpgc
I know of lots of cars that have clean engine oil for a long time and a lot of miles after an oil change. I convert vehicles to run on...
Oct 4, 2026
dingbat
Garmin Striker Vivid 7SV and Transducer
What is it doing? Transducer failures are common. Head units, not so much. If the head unit turns on, it’s most likely a problem with...
Oct 4, 2026
dingbat
Transducer mounting Question?
I have both thru hull (conventional CHRIP) and side scan transducers on my boat. The thru hull is mounted on center line, 18” in front...
Oct 4, 2026
redneck joe
when shopping for shackles they are rated
Oct 4, 2026
rickasbury
My safety chains are a hot mess. My chains themselves are I'm sure sufficient but the ends are just some S'S from a box store, have no...
Oct 4, 2026
rickasbury
reacted to
Captain Caveman's post
in the thread
with
Like
I guarantee that 9 out of 10 people that buy a setup like that will never use it. It's like the jeeps that you see driving through the...
Oct 4, 2026
E
ejnichol
5.0 gxi-e Fuel Pump Issues?
alldodge suggestion is what I would first check, the relays. Have a 2007 with 5.0 GXi and it quit starting last summer with little...
Oct 4, 2026
