  • J
    Jeff J replied to the thread safety chain question.
    10K behind an F150? They must have really upped the limit on the newer trucks. Mine legally caps out about 7500 pounds.
  • Scott Danforth
    Scott Danforth replied to the thread Surge Brakes.
    yes, the fluid needs changing about every 5 years the slide pads wear and the shock may or may not be working as they only last a few...
  • rickasbury
    rickasbury replied to the thread safety chain question.
    Here is what I need for a 10k traiker. I have to measure my chain but I think I'm 3/8". Current S hooks would only be go for holding up...
  • redneck joe
    redneck joe replied to the thread safety chain question.
    i think best bet is to start your own thread about your specific issue.,
  • rickasbury
    While I'm concentrating on my trailer, which has surge brakes, is there any service to the coupler? I don't recognize looking at it any...
  • J
    Jeff J replied to the thread Transducer mounting Question?.
    Sorry, I didn’t catch how shallow that rig is setup to run or that the transducer would pretty much be in line with the prop hub. My...
  • rickasbury
    We may not be talking about thr same type s hooks...these I can barley get one end into the chain...these are a hardware item like you'd...
  • J
    jlh3rd replied to the thread rant.
    GM ?
  • tpenfield
    tpenfield replied to the thread Ants in the boat.
    Might have not seen the frequent DoorDash deliveries to the boat. :ROFLMAO:. I've had ants in one of my boats . . . not sure what...
  • J
    jlh3rd replied to the thread Ants in the boat.
    you didn't read the ad. You put about 3-4 inches of water in the bucket and a dab of peanut butter on the plank. They can't get out if...
  • OutboardBuddy
    iboats Mercury | Mercury 200 series 20hp keikhaifer weak spark? Weak spark on both leads or just one? That tells you a lot. Here's what...
  • J
    A pic would help, I can't "see". My 24' '06 pontoon originally, yes, was 3 sections/ compartments...nose cone, center, and aft. My new...
  • OutboardBuddy
    remove the rubber exhaust seal, then lever under the base, it will start to come. the base (if its been in for a while) may damage when...
  • B
    bakerjw reacted to Chris1956's post in the thread Ants in the boat with Like Like.
    We had Hurricane Sandy in 2012. It drowned all the bunnies and mice, which has been good for us. The bunnies have been relentless...
  • C
    Chris1956 replied to the thread Ants in the boat.
    Sure looks good, however the mouse in my garage ate thru the tote I had the birdseed in and climbs in and out all the time. He would...
