  • Scott Danforth
    its a marine pan. found in the ford industrial line of parts. you WONT find it looking in the normal automotive parts location...
  • Lou C
    Lou C replied to the thread Water in exhaust manifolds.
    I was checking some stuff in the boat today (things to be fixed over the winter) and checked the inside of the manifolds again, they...
  • Lou C
    Lou C replied to the thread Winterize.
    Yep definitely looks cobbled up but does it cool properly?
  • Lou C
    Lou C replied to the thread Milky oil.
    I used Fel Pro on mine, trying to remember from when I did it like 9 years ago...both cylinder heads are actually the same casting. Try...
  • Scott Danforth
    Scott Danforth replied to the thread Winterize.
    None of that is factory. hose sizes jump all over with questionable connectors. looks like a 3.7 or 4.2 heat exchanger connected to a...
  • A
    airshot reacted to Lou C's post in the thread Winterize with Like Like.
    Is the exhaust manifold on the closed cooling circuit? If not then it has to be drained, and even if it is, the elbow should be drained...
  • redneck joe
    with a canvas cover. a bit early but it needs a shaft seal and i've got enough things to do until next spring. Had one good day and...
  • nola mike
    nola mike replied to the thread Winterize.
    Whoa. Lot going on there. Did anything like this come from the factory? Looks pretty hacked together. I can't see the manifold hoses...
  • B
    What is your service manual indicating with respect to voltages to the sensors?
  • nola mike
    I like 4200. Satisfying squish lets you know that there isn't room for water in there
  • reginaldo
    Maybe the water pipe connection between lower unit and powerhead? I’d remove the thermostat and see if water is present/flowing through...
  • O
    What pan is this? It is at end of life with cracks and corrosion but I can't determine what it is. Every SBF pan I find is a 'front...
  • S
    SeaRayboater95 replied to the thread Milky oil.
    Hey People, just wondering if there is an up or down When placing this gasket on the block. The only marking is Marine on one side. Both...
  • reginaldo
    reginaldo reacted to hl's post in the thread Old Ranger with Like Like.
    I bought the Ranger in 2005 from the original owner. My wife was in the boat one time and said she would never get in it again, which...
  • reginaldo
    reginaldo reacted to redneck joe's post in the thread Old Ranger with Haha Haha.
    or are you wanting proof for the wife it needs to be replaced with a newer fancy one? If that is the cast, tell us here then start...
