  • S
    saltchuckmatt replied to the thread Discoloration on outboard.
    Industrial viniger is much stronger...(30percent) Than store stuff. CLR is homeowner stuff and not very powerful. Looks like it worked...
  • MRS
    MRS reacted to tpenfield's post in the thread Getting New Knees . . . with Like Like.
    I am managing to avoid the in-laws at Christmas, since I'll be getting the first knee done only a few days before. Looks like we will...
  • MRS
    MRS reacted to ezbtr's post in the thread Getting New Knees . . . with Like Like.
    A buddy of mine (63) just had it done a few months ago, was on a walker for maybe 2 weeks, was walking on it unaided after 5 weeks!!!!
  • JASinIL2006
    JASinIL2006 replied to the thread Deck repair for seats?.
    I went a similar route to what Froggy took. You can check it out in my resto thread...
  • tpenfield
    tpenfield replied to the thread Fiberglass thickness..
    So, what is your question? rounding corners? building back what was there? I would use 1708 more so than CSM . . . Each layer of...
  • WIMUSKY
    WIMUSKY replied to the thread Random.
    Nice pic, Joe. But I can see you out kicked your coverage...😁
  • WIMUSKY
    WIMUSKY reacted to redneck joe's post in the thread Random with Like Like.
  • JASinIL2006
    JASinIL2006 replied to the thread Crack in Stringer.
    Hard to tell without a good moisture meter or drilling a hole into the stringer. That large black hose running from the top to bottom...
  • C
    you may want to compare base gasket shapes. It may indicate if you can swap heads.. wait for extra comments
  • PatinIdaho
    PatinIdaho replied to the thread Fiberglass thickness..
    No. Im not trying to keep that at all. That pic was to show what was. When i cut them out they will pretty much be down to what the...
  • M
    Yes I know that , at no point did I suggest that a loose throttle shaft was causing the leak :rolleyes:
  • S
    SeaRayboater95 reacted to Scott06's post in the thread Milky oil with Like Like.
    if you look at the way a lot of gauges are wired the ignition on voltage from the key is often daisy chained through the gauges, a lot...
  • S
    SeaRayboater95 reacted to Lou C's post in the thread Milky oil with Like Like.
    True, what I found: battery on, ignition off, the fuse box positive feed had battery voltage, and the B terminal on the ignition switch...
  • tpenfield
    It looks like you are trying to preserve the outer fiberglass layer of the engine mount stringers. If I were going this, I'd mix up...
  • Scott06
    Q-jet has a big problem with this . Any decent rebuilder will bush them as they will be better than new. only reason not to is if you...
