  • B
    bakerjw replied to the thread Rear Floor Removal.
    In this image, I believe that the engines are under the aft deck with the pull ring and seat post. Ahead of that seems to be the low...
  • curtdad
    curtdad replied to the thread Fuel pump issues.
    Thank you for the response, it is a GL but I have no idea how to identify A B C etc. The fuel pump does come on for a short time, a...
  • C
    original thread is 6 years old ... best to start a new one....and not revive old stuff. manual $20 US easy downloads ...
  • A
    Adam18 replied to the thread 3 cylinder nightmare.
    I actually believe the schematic to be mis labeled (if you look at a different similar motor with the same thermostat housing the...
  • E
    ejnichol reacted to alldodge's post in the thread Fuel pump issues with Like Like.
    That number doesn't work for some reason VP Lookup Is your motor a GL- A, B, C, D etc? The GL motors use a fuel pump relay and the...
  • WIMUSKY
    WIMUSKY replied to the thread Pythagorean Theorem Trivia.
    I thought the same until I realized those numbers were the date on Sat....
  • alldodge
    No expert on the Optimax but I'm finding that most likely the poppet valve might be stuck
  • dwco5051
    dwco5051 reacted to redneck joe's post in the thread Random with Like Like.
  • C
    A service manual would help you check out the ign system. Marineengine used to sell factory service manuals. You would need an engine...
  • Snowfish
    Been having a blast, with this rig, for a long time. Until now. Coming into the landing the motor quite like the key was turned off...
  • redneck joe
    redneck joe reacted to MikeSchinlaub's post in the thread Rear Floor Removal with Like Like.
    Looking at pictures online, I would expect a rear panel that can be unscrewed to access the engine. I couldn't find the right pic of one...
  • M
    MikeSchinlaub replied to the thread Rear Floor Removal.
  • alldodge
    alldodge replied to the thread Fuel pump issues.
  • curtdad
    No start, no offer, pn 218 2589B. Can here the pump come on momentarily but no feed. I can start the boat on brake kleen, have load and...
  • alldodge
    Welcome Need your full model number or serial number, because a GL normally only has a low pressure pump and uses a Carb. What problems...
