Stalls with cover on
jelybean
Ok, my turn. 1987 19' Bayliner Center Console w/1986 Force 125HP outboard. 4 cylinder and 2 carbs. 30 gals fresh 87 fuel. New plugs and filter. Recently acquired and today was first time on water. Ran well at home w/flush device. <br />Off-Loaded at ramp and it fired right up in neutral. Went to place in reverse and it stalled out. I played the game of "Start and Stall" for about 10 minutes, Forward and Reverse, no difference.<br />Pulled off engine cover to further investigate. Nothing obviously wrong. Fired it up w/cover off-Varoom! Full rpm's. Ok, so my magic touch did it again,put cover back on, engine still ran in neutral, but still stalled in gear. Gotta do something, hogging ramp space and people are starting to stare.<br />Pulled cover, fired up and pulled away from dock. Except for the noise, she ran quite well. Got up on plane decently enough and ran about 39 to 40 mph (by my speedo) at not quite 5000 rpm's (again, by my tach). Spent over 2 hours on the river and lake in Central Florida, but when I got back to port, it still stalled with the cover on (too chicken to try it on the open water!)<br />Now I did notice that w/cover on, there was a lot of churning water out the exhaust.<br />But w/cover off, no disturbance except for pump water out of "Power Flow" twin pee holes.<br />Could I have wrong cover (don't think so). The inlet isn't clogged. Also, where does the air filter go? My Seloc manual is rather complete, but I can't find the answer. Hope I covered all the bases and sorry for making this too long. Now you know my sad story and THANKS for any help. <br />P.S.- With cover on, the rpm's would only go to about 1800. Take cover off and rpm's would increase by a few hundred rpm (just by taking cover off). <br />P.P.S.- Please remember, It ran very well (I think) with cover OFF.
JB
Re: Stalls with cover on
Sorry, Jelibean. I don't have a clue.<br /><br />Could it be evil spirits??<br /><br />Red sky at . . .sundown???<br />JB :)
Bluefish
This is a good one, Could it be evil spirits?<br />First is the vent area on the cover opean no extra foam covering them? You said plugs and fuel filter were changed how is the routing of above things? could you be pinching the fuel line with the cover,or crosing spark wires when you put cover on, any loose wire connection's ?<br />Good Luck
jelybean
I'm not lying, This actually happened not more than 12 hours ago.
12Footer
I've read of this happening here. They never followed-up on what caused it,or even if he found the problem.<br />I had the noise baffle material fall out of a merc,and contact the flywheel. It carried on,but didn't stall. There is no air breather on the motor.<br />The cover is moving something, i would think.<br />But you got me.
ODDD1
Jelly bean, I might have the answer for you....<br /> Whenever you find an outboard that doesnt run with the cover on, it is because its not getting enough air to run properly...now, you may go an look at the air holes in the cowling, but thats not it....if there is an EXHAUST leak inside the cowling, the cover holds the exhaust gases inside and starves the engine for clean air...look inside the lower cowling at the rubber hose that hooks to the back side of those 'powerflow holes' is it leaking? you probably wont find much unless you look for this with the boat in the water....on the garden hoses there is simply not enough back pressure in the exhaust to show a leak....
Yepblaze
Exhaust port cover or powerhead base gasket. You may see a water leak also around the powerhead somewhere while it's running in the water.
jelybean
Hey All:<br />Thanks for giving me a place to start. The exhaust leak makes alot of sense now that I think about it. Let you know what find.
ODDD1
A response would help, jellybean....good luck to you...
design
Guys, a buddy had a smaller older engine, same problem. the seals around the lower unit went allowing the exhaust gases to escape into the engine compartment. Take the cover off and it ran fine.
mtd
I had the same problem on 4th of July at Lake Havasu. I needed a new manifold gasket. It cost only a couple of bucks for the part and 1 hour of labor. Pretty cheap!
kev_79
definately check clanton't idea, it's happened to me when plug wires were routed properly. Make sure nothing is getting pinched when you put it on. Good Luck
trpm74655
Look on the inside of the cover for burnt marks or pitts possibly caused by arcing.<br />good luck REX P.
jelybean
Thanks all for the help. I found the spring clamp that holds the bellows for the "Power Flow" was rusted in two on the under side. It looks like exhaust was coming from there. I'm going to river test tommorrow, so I'll see if that fixed it. Once again, thanks for info and help.
jelybean
Yahoo!<br />That leak at the bellows was it. Runs great with cover on now. I appreciate everyone's help on the subject. <br />Thanks- Jerry
Walter
Excellent diagnosis ODDD1 !!! I gotta tell ya folks...there's no substitute for experience!<br /><br />Walt
Walter
Oops...forgot to congratulate Jerry for heeding the advice given and locating/fixing the problem. Good job, sir!<br /><br />Walt
