Power trim
mikehite0325
I have a Force 125 on a 16' bayliner cobra sometime's the trim works and sometime's it dont. Could it be a bad battery? the switch has power to it. just looking for input. Dont know much about this motor. thanks.
12Footer
Re: Power trim
These trim/tilt setups are suceptable to loosing thier ground. Check all of the main ground lugs (black wires, mounted under bolts) that go to and from the area of the CD/Coil bracket. If you find a loose, corroded, or otherwise-bad one, you found the problem, and may have saved your CD pack from an early demise in the process.<br />If this does not solve your problem, you may need to replace the two solenoids. But fear not...They're dirt-cheap, and can be taken to your local auto parts store and cross-referenced for under 10 buks each.<br />Immagine that...A cheap boat part! :D
