stator test
jjpp
when checking stator output test can a vom be used, or do i need special equip<br />not getting spark at plugs<br />1995 force 120 hp ( thunderbolt ign )
chuckz
Re: stator test
You can do a couple of checks with any meter. With the stator disconnected from the rectifier check for continuity between the two yellow stator output wires. Then check each wire to ground, it should be open.<br /><br />The stator outputs a series of pulses. In order to match up the output values with what is published in the manual, you need a peak reading meter or an oscilloscope. With the VOM you can measure yke stator output voltage, on the AC scale, but you can't correlate it to the peak readings.
jjpp
Re: stator test
did a stator resistance test on stator, low-speed reading was a "o" ohm<br />high-speed was a 145-150 ohms
rodbolt
Re: stator test
hello<br /> are you sure it was zero Ohms or was it infinate ohms ?<br />super big difference
jjpp
Re: stator test
now that i think about it , it was infinate ohms
rodbolt
Re: stator test
no further tests are nessasary:). however replacement of the stator is. its a common problem
rodbolt
Re: stator test
before buying the red stator kit check with Rapair. that red kit has gotten kinda pricy.
jjpp
Re: stator test
hey rodbolt,thanks again for the help<br />pulled the stator off that 120 force checked out wireing and could not find any problem must be internal.tried to order stator from i boat parts only to find it was out of stock,did some searching and found one for $20 less from "surplus unlimited" down in daytona beach,fla
