X-ped gas scooter wont start
Lazyrus
i got a xped yesterday everything seems fine and i just replaced the spark plug the engine will turn over but not start...would u help me
Dunaruna
Re: X-ped gas scooter wont start
Hi Lazyrus,<br /><br />Got spark? Pull the plug, connect the plug wire and touch the tip of the plug to the engine. Kick it over (or turn the key). Got spark?<br /><br />Aldo
Lazyrus<br /><br />Welcome to iboats<br /><br />Are you getting spark to the plug?<br /><br />That would be the first thing I would check for.<br /><br />Next is fuel getting to the carb<br /><br />Is this a two or four cycle motor
Lazyrus
i got a spark and its primeing so im pretty sure fuels getteing to carb and its a 2 stroke
Well this will give the experts here something start with Lazyrus. I'll follow the post just to see how it turns out.<br /><br />Luck with the scooter
Dunaruna
Pull the plug again and see if its wet from fuel.<br /><br />If it is, your fuel may be contaminated or too much 2stroke oil. If it isn't, you may have a carby problem or a blockage (fuel filter?).<br /><br />Aldo
Lazyrus
hey where is the oil filter<br />noot quite sure is it the metal box on the back of the motor
Dunaruna
Originally posted by Lazyrus:<br /> hey where is the oil filter<br />noot quite sure is it the metal box on the back of the motor
Can't help with that one. I don't know what an x-ped is. If you mean the fuel filter, follow the fuel line and you'll find it. Sometimes they are built into the tap on the tank.<br /><br />Aldo
Lazyrus
ok well an x-ped is just a different model it has just a standard moter
Dunaruna
What I should have said is that I'm not familiar with ANY model or make of scooter therfore I don't know the location of the filters, but they should be accessible and easy to find (famous last words :D )<br /><br />Aldo
Lazyrus
oh ok well thank u im gonna work on it this weekend and try to get it to work
PW2
Any motor needs<br /><br />1 Spark<br />2 Fuel<br />3 Compression<br /><br />Check all three and get back to us. Does it sound like it is trying to start at all (coughing and sputtering?) Or nothing at all?
Xcusme
Oil Filter??? I thought you said it was a 2-stroke...
Formula1974
are you mixing oil in the fuel? If its a 2 stroke there wont be an oil filter. I got a 50 cc scooter for my son and it is hard to start. It floods the plugs sometimes and others it doesnt seem like its getting enough gas. try and start it a few times and pull the spark plug. is it wet? if it is its flooding, in this case leave the plug out and crank it a few times to dry the cylinder a little then wipe the plug dry with a rag and try to fire it again. this usually works with mine. Also check your spark plug gap. if its too big or small it wont run.
