Re: Tank killing
I'm sorry, but I'm obsessing on this.
No Argument There............................
<br /><br />But, I'll counter with;<br />Your man John, Owns the Company....<br />He's Not a Welder,.... Even though he can no doubt run a company, he knows Little or Nothing about the Nature of the Gas he's Selling,+ as stated, He's Not a Welder.........This is Very Clear with the statement,<br />
7. If you don't go up in smoke, then you can cut the tank open WITH THE WATER STILL INSIDE THE TANK.
Well, For the Same Reasons that you Can Boil water in a Paper Cup, There's No Way you can Ox/Ac Torch Cut Steel, with Water Inside........... Ain't Going to Happen.......<br />You could try a Carborumdum Saw Blades, But, You're going to get Awfully WET........<br /><br />As for His Other Points,<br />#1,... Ya, Right...Most of the Gas Employees I've met know Only what they've been taught about Moving,+ Storing Propane, as per any printed guidelines....No practical experience, or understanding of the
Nature of the product they're working with............Not that there aren't some Very Knowledgeable folks working for Gas Co.s, But Most, Only Know
Their Job.........<br /><br />#2,... Ya, Right...... They'll Laugh at you...Or, Refuse for Liability reasons, Etc.......<br />Besides, All it takes is a PipeWrench.........<br /><br />#3,...All that's going to do is,........
Nothing ..... As You've Already Spilled all that
Nasty Smelling Oil on the ground..........<br /><br />#4,...No Help Here... Just Wasting potable Water........<br /><br />#5,...Ayuh,.. No Help Here Either.... Just Rusting the inside of the Tank.......<br /><br />#6,...Ayuh,...Still Wasting My Time......<br /><br />#7,... Explained Above......<br /><br />So BoatBuoy, Yes, I personally think that you're getting Very Anal about it.....<br />
Yourself,+ rwise Seem to be Confusing Propane,+ Gasoline ..............<br /><br />So, Just to recap the Nature of the Fuels We're talking about,<br /><br />
Gasoline is very stable in it's Liquid State....<br />And, between Volatile,+ Explosive in a Vaporous state......<br />And,
Fumes,+ Vapor Will Linger for Damn Near Forever in Any vessel that has
Ever contained it.............<br /><br />
Propane Has to be Under Pressure to get it To a Liquid state,+ is Very Volatile,+ Very Explosive in a Vaporous state(which is Anytime there's No Pressure)......<br />And, It's Fumes,+ Vapor are Easily Moved to the Lowest Point in which they can Flow,+ Do Not Linger.......<br /><br />This thread is about Propane,............
Not Gasoline .............<br /><br /><br />BTW, FYI, Propane Tanks are Very Thick Steel......... <br />20lbers are about 1/8th" thick.......<br />100lbers are about 1/4" thick.........<br />"Pigs" are 3/8ths" thick..........<br /><br />With all that said,<br />
If you follow the points laid out above,....<br /><br /><br />Yes, It's Safe............
