hi Guys, <br /><br />I have been researching this seacast pretty seriously.. read about 100 sites about it..<br /><br />firstly, there is a B-board of sorts on their site. the URL is:<br /> http://transomrepair.com/forums/viewforum.php?forum=3&57 <br /><br />It answers alot of questions, they invite you to email pics to them and they will give advice.. you can also request a hard sample to be sent to you so you can satisfy yourself.<br /><br />other things I gleaned from reading every post.<br />1. they recommend only seacast, don't leave wood in there.. lose all the wood. (ie don't leave the good wood in there and replace the rotten areas only.)<br />2. The seacast guy on the list suggests using a router bit in a drill or a chainsaw.. (he stated he uses the chainsaw himself)<br />3. It will bond well with fiberglass, but not wood or epoxy.. <br />4. its pink.
<br />5. If you cut out the inner skin of your transom (or don't have one), and your boat is small enough to stand upright on its transom, then you don't need to fabricate a temporary inner wall to contain the seacast, gravity is your friend.)<br />6. It can be drilled easily enough once hard.<br />7. It reaches 160 degrees when curing, so don't use tape to block holes.<br /><br />I really hope I can find a way to get this stuff, it looks really good.. and I want some.
<br /><br />This post wasn't really necessary, but I figured I'd summarise it for you guys in case you were wondering.<br /><br />They also have a lot of testimonials in the board and they supply email address's so you can verify they yourself..<br /><br />If you do a search on www.google.com or www.metacrawer.com for seacast, you'll find it mentioned alot.<br /><br />FYI..........<br /><br />regards<br /><br />Frank
