New motor need prop starting point
jy118lfd
Re: New motor need prop starting point
I see it may lift the hull a little more and could be comparable. If you know where there is one I would be willing to try it ;) <br /><br />I am going to raise it a little more as it did pick up 1 mph from the original position. It is now about 2 3/4 above the keel (av plate)
Dhadley
You're probably nearing the optimum point for a Stiletto. Excellent bookkeeping.<br /><br />Send me your address in an email -- dhadley50@aol.com and mark the subject as iboats so I won't delete it.<br /><br />The Turbo 18 you had was a 4 blade, right?
jy118lfd
Took it out today. New carbs from a 94 225.<br />39.8 @ 5600 14.4gph<br />cruise 32 mph @ 4200 8.7 gph<br />I think I need to go smaller in pitch though. Where should I go from here?
Dhadley
Was that with the 17 Stiletto?
jy118lfd
Yup, I have a 15 pitch bmc almnium to try but I know I have to lower the motor before I run that.
Dhadley
OK, with the Stiletto can you use 100% of the trim range or more like 75 or 80% before it starts venting and slows down?
jy118lfd
No at the present height I can't trim it up at all, maybe 1/8 or less through the range up before it loses speed. The rpms do not go up though, it just loses speed. It also will not bite at cruising speed unless trimmed all the way in. <br /><br />Dhadley can you post in my other post (to rejet my 120 or not?) in johnson troubles, about setting the idle mixture screws and link sync of a 94 carb?
Dhadley
That Stiletto should not let loose that early unless it's worn or someone has reworked it using an SST pitch block.<br /><br />The thing that bothers me is that the rpm should go up when it vents and you lose speed. Thats wierd that it doesnt.
jy118lfd
Brand new from Precision, not reworked. I want to try another prop but only have a 15 pitch alumnium to try. I might give that a shot next week. Just to make sure it gets 6000rpm.
Dhadley
Did you send me your address?
jy118lfd
Did you get my address Dhadley?
Dhadley
Got it and sent a package to you today. Without making any other changes just run this and lets see haow it compares. It should be there Thursday.
jy118lfd
Sounds Great Thanks so much. Will post test results asap. Which one did you send?
Dhadley
I had an 18 Lightning Jr. I'm hoping that with the additional diameter and bite it'll work well.
jy118lfd
Great, I will run it at the present height to get a baseline then raise it and post again.
jy118lfd
Well here are the results:<br /><br />41mph @5400 rpm :cool: <br /><br />This was just at the point where trim started to vent the prop, about half way. If I went too far 39mph at 5600 but was able to trim up all the way and not lose the bite any more than that.<br />It needs more height as I had alot of spray from the front of the av plate.<br /><br /> I think this prop is much better suited to the jackplate as the boat seemed better all around <br /><br />Dhadley the blade design is soo different than the stiletto. It seems like the cup was less on the turbo and it did not continue around the blade as far as the stiletto. How does this prop bite so well and have the ability to run as high as it does.<br /><br />I think I want to test some more and will cry when I pack her up for the trip to the sunshine state ;)
jy118lfd
It was also quite windy and 2 to 3 foot chop so not the absolute best testing conditions. I wanted to raise it at the ramp but my fingers were numb and could not turn the wrench. I will raise and retest on sunday
