GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Thanks Dave and dhadley. Boat is performing fine and seems to reach approppriate RPMs and speed, however I was told that I could expect improved performance with a stainless prop. I'll look for the prop forum. Thanks for the FYI.
The improved performance comes largely due to the fact that a ss prop will (most times) run at a higher X dimension than an aluminum one. Raising the motor to find the optimum height (X dimension)for any given prop on a specific rig results in less drag and therefore better efficiency. From holeshot to wot.<br /><br />It's all in the set up.....
