Evinrude 150 prop
jebb
I have an aluminum prop on my 2002 150hp Evin Ficht and would like to change to a stainless. Would the pitch and diameter remain the same?
Dhadley
Re: Evinrude 150 prop
If its set up properly now, probably. If its not, probably not.<br /><br />We gotta know more about how its running now. And the set up.
Dave Abrahamson
Hey Roger, there is a prop forum just for questions like this. Might do better posted there. Just an FYI. <br />Welcome to iboats<br /><br />Dave
jebb
Thanks Dave and dhadley. Boat is performing fine and seems to reach approppriate RPMs and speed, however I was told that I could expect improved performance with a stainless prop. I'll look for the prop forum. Thanks for the FYI.
mikeyzx2
Stainless won't flex like aluminum, that's where the SS props have an advantage....
moderator1
I think we need to head to the prop forum with this one...
Dhadley
The improved performance comes largely due to the fact that a ss prop will (most times) run at a higher X dimension than an aluminum one. Raising the motor to find the optimum height (X dimension)for any given prop on a specific rig results in less drag and therefore better efficiency. From holeshot to wot.<br /><br />It's all in the set up.....
