I suspected I might have a bad primer bulb so I went to West marine and bought a new one. The new bulb goes flat after I run the motor on idle for 5 minutes but does not stall. It probably would with a load. My fuel filter only has maybe 15 hours on it. I took the line off of the motor and the line off of the tank and I can blow the gas through the line, filter, and into the can I had the hose in so no clogs there?? I took the connections off of the tank itself. The check valve in the piece that is barbed and gets connected to the hose seems ok, and the screen in the other part was clean??? If my vent is clogged I should be able to take the cap off the fill to see if the bulb inflates? If it does not can I take the spring and ball out of the barbed piece and it still function ok?? My boat is a 17foot Mckee Craft with a 1988 110HP Johnson. Any input would be greatly appreciated. Thanks.
