Re: Fuel Primer Bulb Goes Flat
MrMckee said:
I took a break from my tank today and ran through my head every possible scenario. This problem defies all logic. More food for thought, the boat runs fine when I have a full or 3/4 full tank, but once it hits 1/2 a tank that is when the bulb colapses. Does my pick up tube have a hair line crack?? I say no the bulb would still inflat with air, right??
Hey MrMckee, Slow down and take a breath. When your tank is 3/4 and full the weight (5.6 pounds per gallon) of the gas adds fuel pressure to the lines and it's works fine. There is a restriction caused something being partially obstructed, that's for sure.
Fuel restriction from the tank to primer bulb can be anything from a:
(1) The pickup in the fuel tank patricianly clogged.
(2) The Fuel line that is to small (inside diameter) for the FPH (fuel per hour) for your engine displacement.
(3) The Fuel tank that is not properly venting and creating a vacuum.
(4) A defective anti-siphon valve the is defective.
(5) Fuel flow path is inadvertently reversed, all arrows must point in the path to the engine.
It's time to slow down and breath MrMckee.
In order for an engine to run properly it must receive an uninterrupted and unrestricted flow of fuel. This cannot occur if improper fuel lines are used or if any of the lines/fittings are damaged. Too small a fuel line could cause hesitation or missing at higher engine rpm. Similarly, a clogged fuel line, fuel filter or dirty fuel pickup or vacuum lock (from a clogged tank vent as mentioned under Fuel Tank) could cause these symptoms by starving the motor for fuel.
Check the tank first to make sure it is properly vented, then turn your attention to the fuel lines. First check the lines and valves for obvious signs of collapsed hoses that could cause restrictions.
If there is a restriction between the primer bulb and the fuel tank, vacuum from the fuel pump may cause the primer bulb to collapse. Watch for this sign when troubleshooting fuel delivery problems.
No matter what type of tank is used, all must be equipped with a vent (either a manual vent or an automatic one-way check valve) that allows air in (but should prevent vapors from escaping). An inoperable vent (one that is blocked in some fashion) would allow the formation of a vacuum that could prevent the fuel pump from drawing fuel from the tank. A blocked vent could cause fuel starvation problems. Whenever filling the tank, check to make sure air does not rush into the tank each time the cap is loosened (which could be an early warning sign of a blocked vent).
Hope this helps a little, OUCH my fingers from typing... :/
If you only look for the complex,
you will always miss the simple.
Brian~
