what oz mat to use on stringers
ondarvr
Re: what oz mat to use on stringers
1.5 oz is easy to get and what you need.
klos
I use 1.5oz mat and one layer of biaxle cloth, the kind with mat on one side and the cloth on the other.
epresutti
bingobongo,
I used XM, which is cross stiched woven with a 1.5oz matt backing. Very hard to wet out, If I were doing it again I would do it in more than 1 layer with woven and matt.
Peace.
Ed.
ondarvr
If you were only going to use mat it won't be that strong, you need roving or Biax in it for strength. Roving and mat is the easiest combination to use.
BillP
1.5oz mat alternating with 18oz or 24 oz roven. Mat goes on first.
bingobongo
i guess i will use the 1.5 mat first then use the roven over the mat. should i go entirely over the stringer with the roven or just the sides of the stringer and the hull does roven also come in different sizes if so what should i use and what particular brand do you guys suggest i should use, be patient with me guys this is my first time doing this
ondarvr
It's best to run it over the top, make sure there is room for the deck to set back down on it (don't build it up too high). There are different sizes, but you can cut it to any size you want if you can't get what you need. You will find two weights of roving, 18oz. and 24oz., 18 is easier to use and 24 is stronger, but get what's availible it won't make a big difference. You won't know the brand when you buy it and it won't be an issue.
