jimmer4444
Thread starter- Joined
- Aug 16, 2001
- 30
I was thinking of fabricating an I/O into a pontoon boat,has anyone seen this or done this before?
Keep in mind your adding a lot of weight probably need the biggest logs possible your adding a heavy power source and the modifactions needed
to make it work.Getting the height right will be an adventure.
There are several manufacturers that do it that way and it is inherently unstable, you are effectively making a outrigger.
The boat will never find a center and be VERY upset by waves and wake since it is floating mostly on the center tube.
I actually know someone that was driving one pretty fast, they turn hard to port, in the middle of the turn the boat hit a wake and flipped to the starboard side, so he is turning left and the boat is banking right, very bad design, it is good for banking the toon but is a major comprimise for every other area of the boat.
