likwidsukr
- Joined
- Oct 1, 2006
- 30
I have a Sea king. It was made by Clinton Engines.
Model # K5011064
Serial # 432415
Type # 60 27205 R
First what year is this?
I cannot get this to run consistantly. It has 360 degree reverse (forward only but swivels 360deg) It is air cooled. Water cooled exhaust/shaft. I have cleaned carb, played with the idle screw also the srew at bottom of the bowl. I also took apart the housing where the reed valves are no problems there. Sometimes it runs alright but then sometimes not. I barely made it back today. I have a 10' Jon boat it will not plane with me 190lbs. Gas tank 5 gallons. Boat may weigh 100 lbs wet. And that is when it is running good (decent) At best i showed 6 MPH wot With GPS
Any thoughts?
Model # K5011064
Serial # 432415
Type # 60 27205 R
Any thoughts?
