1988 225 Evinrude cuts out
Lucky Day
Hello all...
I have a 88 225 Evinrude. Last week i was running about 3500 rpms and the OB just cut out on me. It does it everytime i run it open from 3000 rpms and up and run for about 2-5 minutes. Funny thing is after it shuts down..it starts right back up so i dont think its a fuel problem. I was able to run home at about 2500 rpms with no problems. Does anyone have any ideas where to start?
Re: 1988 225 Evinrude cuts out
high speed jets clogged? check if the bulb on the hose is calaspsing. when it cuts out.
Lucky Day
Not sure about the jets... i did check the primer bulb while it was shutting down and it was hard...
JUSTINTIME
sounds like fueling problem
when was last time u tuned it?
Lucky Day
I changed the plugs about 2 months ago. I am also having a problem with the plugs loading up at an idle. Thats why i changed them. Once i open it up it clears out and runs fine up until this last problem of it cutting out on my.
Lucky Day
I changed the plugs about 2 months ago. I was having a problem with the plugs loading up at an idle at that time. Thats why i changed them. Its still doing it but once i open it up it clears out and runs fine up until this last problem of it cutting out on my.
JUSTINTIME
u need to rebuild the carbs and sync and link it
Walker
Test your recirculation valves.
