Re: What Is This and should it be leaking fuel?
i couldnt get your pictures to come up, but as previous poster said,its likely your primer,there are three plastic nipples on it,if the gas was always flowing i would say it was on the feed sise,but most times the smaller nipples break off ,this also causes harder starting because depending which is broke,those cylinders dont get the prime.it could be the top of the unit cracked,either way,you can buy the new top,once the unit is removed by removing the two hold down screws and the wiring,there are four screws on top of the primer that allow it to come apart,not hard
