1994 225hp wont start
tropic
Hi, i have a problem, the engine have not spark the mechanic take out the sparks plugs and when tray start the sparks came on . He said its the power coils.
this is posible? thanks....
ezeke
Re: 1994 225hp wont start
Possible, but;
You may need a more powerful battery or better connections. What are you using? Try connecting a second battery in parallel to the starting battery for a test.
You will want to clean all of the ignition wiring connections, especially the ones on the coils.
Battery cables corrode inside of the insulation. Feel the battery connection after trying to start. If the connections are hot, the cables are probably bad.
tropic
ezeke said:
Possible, but;
tropic
Sorry i new with this.
the battery is new, all the connections to the battery are new, the coils cables are new . Volt with tester is 100v and he said its low this may 130 volts.
Ah we put a second batery and nothing
ezeke
Do you have a tachometer to see what revolutions [rpm] are when trying to start?
tropic
I have but...... doesnt work!!!!!!!!!
tropic
I´ll try to fix the tacometer first bad connection or something like that. Is a two engines boat i can put one on the other. No???
ezeke
Does starter seem as fast as usual?
tropic
Yes, the engine start once but them no more...
the another engine start ok and fast
ezeke
Have you checked the flywheel magnets? Are they tight?
Edit: If the wiring has been checked and the voltage is still less than 130 volts, the next check is the resistance test, which would tell whether or not the charge coils on the stator are bad.
tropic
Yes, i repair one its fix and ok
