ezeke said:Possible, but;
You may need a more powerful battery or better connections. What are you using? Try connecting a second battery in parallel to the starting battery for a test.
You will want to clean all of the ignition wiring connections, especially the ones on the coils.
Battery cables corrode inside of the insulation. Feel the battery connection after trying to start. If the connections are hot, the cables are probably bad.
