petrol running from top of carb
antali
thought i would change the impellor on my 80,s yam 15hp when finished i pressurised fuel system with bulb and noticed petrol pouring out of the top of the carb also ran badly ,did have the engine a bit more than vertical when doing the impeller,what do i need to do to rectify this problem as it ran fine this morning....anticipated thanks....antali
JUSTINTIME
Re: petrol running from top of carb
if the motor was in the tilt range u are fine
if the motor was still in the trim mode u could have a bad float setting or bad float
but if it ran fine, i would pull the plugs and look at them
Ray Neudecker
This is normally a sticking needle problem. Best to tear down the carb, clean throughly and reassemble with new carb kit including needle and seat.
antali
thanks justintime and ray will strip carb today and check float and needle
antali
stripped the carb today and found the needle stuck so replaced it,and it goes well now, thankyou for your help.
