Penta 275 stern drive prop question
joleda
I have a 1986 Bayliner with a Volvo 275 stern drive. The prop that came with it is a 14x21which needs replaced. The owners manual recommends a 15x19. This is a long hub stern drive. What would the benefit be of the 14 versus the 15 or visa versa? Please help.
thanks,
Dave
JUSTINTIME
Re: Penta 275 stern drive prop question
what is your WOT right now fully loaded and trimed a little up?
joleda
I am a little new to this. What is WOT? Also I have never had this boat in the water yet.
joleda
Ok. I am still confused. The max RPM for the engine is 4400 RPM and cruising RPM is 3600RPM.
Dunaruna
[colour=blue]You need to determine what you WOT RPM's are with the 21" prop and then make a determination as to what best suits your boat.
You need to baptise the boat and do some test runs. Do you have a tachometer? How badly damaged is the 21" prop?
There are members here that can give you detailed information but you will need to supply a bit more information such as boat size/model, engine size/model etc etc.
JUSTINTIME
so u want to be around 4300-4400
u need to do sea trails
