FORUM RULES UPDATED - - - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for . . . Forum Rules
I'm going to replace the impeller in my 2003 60HP Merc (Serial Number: 0T680439 Model Number: 1060412AN) and was wondering should I have the motor in forward, N or reverse when removing the lower unit?
My 96 60hp Merc says have it in forward. I always have to reset the shift lever after each replacement and I have done it 5 times. The only caution is make sure you have ALL of the bolts/ nuts out before you try to pull it apart. Mine has one under the zinc skeg. The first time is a bear getting it apart. Good Luck
Yep Kajun its me from KM. Damn Water pump went out on my my last trip down the James. Normally I would consult the manual for such things but I have temporarliy misplaced it (aka lost for now). And want to get back on the water asap.
I thought it was forward. Thanks for the replies everyone.
