FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I'm going to replace the impeller in my 2003 60HP Merc (Serial Number: 0T680439 Model Number: 1060412AN) and was wondering should I have the motor in forward, N or reverse when removing the lower unit?
My 96 60hp Merc says have it in forward. I always have to reset the shift lever after each replacement and I have done it 5 times. The only caution is make sure you have ALL of the bolts/ nuts out before you try to pull it apart. Mine has one under the zinc skeg. The first time is a bear getting it apart. Good Luck
Yep Kajun its me from KM. Damn Water pump went out on my my last trip down the James. Normally I would consult the manual for such things but I have temporarliy misplaced it (aka lost for now). And want to get back on the water asap.
I thought it was forward. Thanks for the replies everyone.
