Re: 70 HP Evinrude VRO Information
Thanks Rick. I just got the boat home today so now I can start getting the parts and all that good stuff for her. Below is a list of things I am going to buying/replacing. Tell me if you think I should add anything to the list. The only thing we really know is that the engine will fire up. We are not sure how she runs in the water or any of that yet. But to prevent any damage that could happen, I am looking to fix the below.
* Ignition key.
* Lanyard for automatic kill if for some reason the driver was ejected
* Fuel Filter.
* 2-Stroke Oil.
* Lower unit lube.
* Water pump repair kit with housing.
* Service manual is on the way.
* Flush muffs.
* Spark plugs.
I have looked at most the wires and none of them really seem dry rotted so they should be good. Once I get these parts I plan to do the following.
1- Drain the oil from the oil tank.
2- Drain the gas from the gas tank.
3- Drain the oil from the lower unit.
4- Remove the spark plugs and replace them.
5- Install the water pump kit and housing.
6- Replace the oil in the lower unit.
7- Add two stroke oil to the oil tank and mark the level.
8- Add a gas/oil mixture to the tank at a 50:1 ratio.
9- Put the muffs on, crank the water on and fire her up... and hopefully she will fire right up and run fine. If all is well at that point. I think I might take her to the water and make sure the boat floats and all that good stuff
Does that sound about right or am I missing a few things? How should I know if I need to do anything to the carbs? The guy I got it from said that if I run her slow and what not... the carbs will clean themselves out, is this the case? I also read about people spraying something in the carbs while the motors running and it will clean them up but it smokes like all get out! What do you recommend I do?
Thanks again.
