2dlking said:How hot should the water coming out the engine be on an 87 Mercury 150HP XR2?
gss036 said:Are you referring to the warning horns? Intermentant is oil, solid beeeeeeeeeeeeeeeeeeep is temperature.
You need to figure out what your problem is before to ruin the engine. Check the thermostats, they open at 143 degrees. At what RPMS are you getting the alarms?
