87 Mercury 150HP XR2 Water Temperature
2dlking
How hot should the water coming out the engine be on an 87 Mercury 150HP XR2?
chiro757
Re: 87 Mercury 150HP XR2 Water Temperature
water should never be hot on any motor. i have smaller mercury that ran hot. hot to the point where you can burn your hand in about 1-2 seconds. i needed a new thermostat. im not a mechanic but thought i would give you the information i have learned. the thermostat was 10 bucks and easily to install. hope you get some other replys as well.. good luck and good boating.
Silvertip
Honorary Supreme Mariner
You may feel a slight change in water temp at the tell-tale as the thermostat cycles open and closed but you would never burn yourself or even come close to it. In fact it could best be described as barely luke warm.
2dlking
It is very hot to the touch and I getting both a intermidete tone and solid tone. What could the problem be?
gss036
Are you referring to the warning horns? Intermentant is oil, solid beeeeeeeeeeeeeeeeeeep is temperature.
You need to figure out what your problem is before to ruin the engine. Check the thermostats, they open at 143 degrees. At what RPMS are you getting the alarms?
2dlking
The sounds are coming a higher rmps and it will stop and idiling rmps
andy6374
The situation you describe can be one of two things.
1.) Sounds like the poppet isn't opening. You'll need to pull the pressure relief valve housing cover and check out all the components. And you mine as well replace it all while you've got the bolts out. It's located right under the switchboxes.
2.) Or the hub on your impeller could be slightly spun to the point where it grips the impeller at lower RPMs and not at high RPMs.
Do you have a water pressure gauge?
Silvertip
The intermittent beeps indicate an oil related problem. Lack of oil can cause an overheat condition hence the two different tones. As was pointed out, the thermostat and poppet valve (pressure relief valve) could also be causing the overheat condition. Because there is oil in the tank does not mean it's being delivered to the engine. I would not run the engine except for diagnostic purposes until both issues are thoroughly checked and corrected. If the water pump impeller has not been replaced in the last couple of years, that should be done as well.
