steve ypsi mi
- Joined
- May 6, 2007
- 10
I bougth this 1991 15 Evinrude out board with controls used about 3 years for a trolling motor on a sea ray 22.5 foot and took it out and it started and ran but when I shut the key off it wouldn't stop the motor so I choked it. I only used it that one day 3 years ago...
this year 2007 I was trying to get it started and it wouldn't turn over, I started it by leaving the key on and rope starting it so it does run. when I turn the key on it seems to be sticky and stays in the crank posistion but doesn't crank, also the beeper comes on when I turn the key on and when I push to choke I can hear the electric choke clicking on but it won't turn the motor over, I tightened the screws on the switch but none were loose.
I also can leave the key on and use a jumper on the solnoid and it will turn and start.
I looked for a fuse on the engine but couldn't find one but if it starts and runs it shouldn't be that I would think but what do I know.
I didn't want to go thru the expense of getting a switch and its a real bear to swap out because the wires are so short if I didn't need to but I am leaning toward as the switch is wore out inside on the cranking part of the switch.
any one think that the switch is wore out inside, every thing works but the cranking part
I have a 3 postion switch, on, start choke looks real similar to this
Item #MP39760
Ignition Switch
Push-to-Choke; Off-Run-Start; Delrin, stainless steel. Push to choke feature, 6 terminals, special weather proofing seal and drain holes. Mounting bushing 1/2" long, 13/16 diameter replaces Johnson-Evinrude 388173, 390129, 390133, 393301 and 508180.
Quantity $26.29
Item #MP39760
Ignition Switch
Quantity $26.29
