Yamaha 90 With No Spark
bruboni
I have recently inherited a Yamaha 90 C90TLRX that has been sitting unused for about 2 years. The starter turns when I turn the key but no spark is going to the plugs. Are there a few things I can check or parts that could have gone bad to replace or repair that may cause this to happen? :confused: I am a greenie and would appreciate your input.
Bruce B.
6H1 L354412
Marc III
Re: Yamaha 90 With No Spark
If the spark is missing on all three. I'd suspect a bad killswitch or missing landyard.
Marc III
I assumed it was a 3 cylinder before I looked up the year model (1999). Those fangled late models have the killswitches under the seat don't they?
bruboni
Thanks Marc,
I believe the kill switch is by the seat. I will check these things later today.
Bruce B.
JUSTINTIME
find the white wire from the cdi box and unplug it
did u get spark?
bruboni
I will do that tomorrow afternoon and let you know. Thanks for your input.
To Marc - The kill switch and lanyard are working and intact.
Bruce B.
bruboni
Justintime,
I unpluged a white wire coming from the box and there was still no spark and a connection with a pair of white wires with the same outcome. I took the time to clean all wiring connections to ensure good contact.
Bruce B.
JUSTINTIME
good deal
now u will need to test voltage output of the stator and triggers
u need a dva and volt meter, or u can use ohms but that is not the best test, because i have tested things that it ohmed right but the volts were not in specs
Ray Neudecker
Be sure the battery is good. If it doesn't spin the motor fast enough it will not fire.
bruboni
I will get ahold of the tools to check the voltage output of the stator and triggers and make sure the battery is fully charged. I am in the process of moving and it may be a couple of days before I can get it done.
Bruce B.
