Vro
Fishstick1962
Does anyone know what year Evinrude came out with a 50hp VRO? Thinking of buying one, but seller is not sure of the year model. He said it was the first year they sold this motor.
WillyBWright
Re: Vro
1984 was the first VRO year, but not all models were VRO the first year.
Fishstick1962
Re: Vro
Thanks Willy, so it is at least an 84 or newer. I will know more about it tomorrow.
snipe401
Re: Vro
Older model VRO pumps are bad about going out. Might want to convert to mixing oil yourself. Just remove the old combo Fuel/VRO pump. Plug the lines, then install the old style fuel pump. Be sure to mix your gas/oil 50:1.
I just did one. Not too difficult. Results might shock you. Mine runs better without the vro. Might also want to put in a water/fuel seperator type filter and remove the one in the engine compartment. Lots less hassle, and easy to do while your working on the fuel system anyway.
studlymandingo
Re: Vro
If you can post the serial number of the outboard, someone here could help you to identify the year.​
