Handling question
PSiedTSi
I am kind of a n00b to really technical boating performance, etc. Anyway, I was curious if there was anything I could do to get my outboard to sit in the water while cornering hard? I believe it only does it when turning right, but I don't remember after the long Minnesota winter :). Someone was talking about something the other day to me, but I can't recall the exact name.
Thanks!
Tony
Boat is a Four Winns 160 Freedom with a V4 120 OMC/Johnson outboard.
Re: Handling question
trim down, slow down, hard cornering is dangerous. the engine is cavatating, sucking air instead of water. take a safe boating course. there should be plenty.
Reel Poor
Trimming the motor down a little my be enough to keep it from cavitating. If that doesn't do it you may need to lower the motor mounting position by one hole.
PSiedTSi
It's even when I'm going pretty slow. I'm not too worried about controlling the boat, etc. I've been around boats for a pretty decent amount of time, just never took the time to learn a ton of technical information. I guess the cornering I am talking about at a decent speed isn't really "hard", just leaves a little to be desired. Trimming down helps a little bit until I hit that point again. I guess I will try to take it out again ASAP and try some more things out. It corners fine to the left anyway.
The motor also has a pretty large hydrofoil if that makes any difference...
get that damn thing off, that what causing you problem. the guy who invented them should be hung. if you have planeing problems after taking it off get a set of Smart Tabs.
PSiedTSi
haha will do...will be getting intimate with it today hopefully...
Will the Smart Tabs hurt anything?
