cant wait to get in water
rsmith032
can some one please tell me where the circulating pump is on this boat 67 evinrude I/O it will take a few days before i get my manual that is of course, if I orderd the right one.
rsmith032
Re: cant wait to get in water
Have Ive been given the wrong information from the seller? I was told it is a 1967 Evinrude sportsman V6 buick 155 omc. inboard/outboard. or did I misunderstood. now I am really confused
whywhyzed
Banned
EDIT:
I knew immediatly after posting that there was no such thing as an Evenrude IO, that I probably should have kept my fingers off the keyboard.
http://hhscott.com/evinrude/all_omc_boats.htm
Haha- the 60's were weird times!
There are tons of those things around my area- They built the stuff in Peterborough here for years. There's even a few special executive "1 off" models hiding in people's boat houses.
The circulating Pump is on the front of the engine. The raw water pump is in the bottom of the upper unit of the outdrive.
To access raw water pump, you need to remove the drive, and split the upper and lower halves by removing the cover off the top of the exhaust housing.
Then flip the uper upside down on the bench, and when you look in under the upper, you'll see 4 bolts- those 4 bolts hold the w/p and lower bearing housing into the upper.
